jardine6141
problem on start up.
hi, i keep getting a message on start up saying spmgr.exe stopped working, it then recovers its self, vgn tt1  w7 ultimate 64 bit. many thanks  carl.
This is Sony Power Management which runs on start-up.
If you are running Windows 7 64-bit, the 32-bit Utility programs supplied for your Vaio will probably not function properly. I would try installing the 64-bit Windows 7 compatible version of Vaio Power Management provided for the VGN-TT4 Series of Vaios here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-TT4
:wink:
:wink:
jardine6141
many thanks , all working normally after your advice , rgds carl.
