Problem with bright in the display in VGN-FS315Z
JOMABOL
Sorry for my englis, it's very poor...
I have a problem with my VGN-FS315Z, the bright in the screen up and down and I cannot control it.
What can I do?
Many thanks
Thalamus.
Champion
Hi JOMABOL,
Welcome to Club Vaio, :slight_smile:
Do the other Function keys work, ie brightness..?
If not then download the Preinstalled Utilities for your FS315Z, once downloaed extract and then install the following, in order.
1 Sony Utilities (install folder 1)
2 Sony Shared Library (Install folder 2)
3 Vaio Event Service (Install folder 5)
Once completed then re-boot your vaio.
You may have to do this more than once before the function keys work...
:slight_smile:
JOMABOL
My Function Keys work fine. At this moment the function key for bright (Fn + F5/F6) work prefectly, but in some ocassions the bright in the screen up and down and these function keys don't work....:smileycry: :cry: :cry:
In this moment the screen is up the screem to maximum...
JOMABOL
I have just to update Bios and at the moment the screen work fine :slight_smile: :slight_smile: :slight_smile:
Is it possible this is the solution?
Regards!!1
