problem with gaming
EPU8787
problem with gaming
I've a vpcec2s0e and i am facing some problems. The most annoying prob is when i play a game that requires high graphics memory(for example: Spider man: shuttered dimension), the system hangs. then i have to restart the system. Can anyone please give me a solution?
Have you installed the updated Graphics Driver available for download on the support page for your model?
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VPCEC2S0E_WI
If so then you may have to play the game with reduced graphics settings.
:thinking:
EPU8787
Thank you so much for your advice. I'll install this update.
