Problem with Roxio Media
djwoody
I have just recovered my Vaio back to its original state and now I cannot use Roxio Digital Media.
When it is loading up i get the message (please see attachment).
Hope you can help
Chris
Thalamus.
Champion
Hi DJ Woody,
What model Vaio do you have..?
Was Roxio Digital Media pre-installed on your vaio, if so you may be able to re-install see below (I'm presuming you have a Vaio with a hard-drive recovery system)..
Goto Start > All Programs > Vaio Recovery Tool and click on Vaio Recovery utility.
Once the Vaio Recovery utility has loaded, click the options button and select Recovery Specific Applications that were pre-installed, click OK, then Yes and Yes again.
Unfortunately not all applications are available for recovery in this way, therefore you may not see Roxio Digital Media in the list... :slight_frown:
