Hello all, I am having problem when i try to watch TV in my laptop. The problem is when I use the media centre a video Error appears and when i try to configure again the settings it appears that my tuner doesn't appear. I checked the tuner driver anmd is working properly. This is the second time that happens. The first time I made the recovery for the all disk but with all the programs that i have installed again it is a wasdte of time and this computewrs are not cheap..
Thanks in advance for your needed help..
Hi jmhorrillo and welcome to Club Vaio.
I'm not sure if it is exactly the same problem but have a look through this sticky thread:
http://club.vaio.sony.co.uk/clubvaio/gb/en/forum/viewthread?thread=36767
the link that blencogo sent is the correct one. just follow the instructions on the first post of the thread and it will work fine. I had the same problem on my AR11M and solved those instructions solved the problem straight away
