For a couple of months now, the ventilation system of my laptop has been very loud. It seems that it is working at its top "speed" almost all the time and my computer still gets very warm. I don't know much about laptops as far as technic is concerned, but I use it a lot for architectural design works. Is it bad? What should I do?
Sounds like you may have dust and dirt clogging the fans and other parts of the cooling system. Try cleaning out with judicious use of a vacuum and compressed air can.
