Problems after downgrading my TZ to XP (Vaio Update)
Unfortunately you cannot use Vaio Update after any change of Operating System.
Vaio Update can only support updates for the original operating system - so it does not work at all if you change from Vista.
You will have to update manually.
:slight_frown:
0 REPLIES 0
