I recently bought my noteboork VGN AR31S with Vista.
When trying to print a Mocroso0ft Works 8.5 document the following message appears:
"Ms Works does not work anymore. The program will be closed"
After pressing OK thr program closes.
Who van help me to clear up this problem.
Grandpa Rob
I can't help you there. But I can highly recommend [url=http://projects.openoffice.org/native-lang.htmlOpenOffice[/url].
Hi Grandpa Rob,
welcome to Club Vaio..
Unfortunately unless anything has changed the only way to re-install MS works is to run the Vaio Recovery utility and recover your vaio back to it's original settings..
Have you ever been able to print MS works documents on your AR31S?
