On my vgn-s5vp whenever i change the power settings, I get an error window saying: run a dll an apphas encountered a problem"
Any solution for this?
As the application that you are trying to run is presumably connected with Power Panel I suggest that you try re-installing the Vaio power management utility.
If you download and extract the pre installed utilities for your model from Vaio-link, I think that you will find this in Installer folder 5.
That said, it may be conditional on other utilities so the safest option would be to re-install all starting in folder 1.
Did what you suggested. Problem is still there.
Any other suggestions?
