HI GUYS I HANE A TERIBLLE PROBLEM
I STICK VIRUS,SPYWARE, MALEWARE ETC
MY WINDOWS XP DOSENT WORK
I DONT HAVE RECOVERY DISK
VAIO RECOVERY TOOL IS BLOCKED I CANT USE IT
WHAT CAN I DO?
HELP
Hi AIZEN,
welcome to Club Vaio..
Can you access safe mode, (Start your vaio and press f8 when you see the Vaio Logo) then try cleaning the Virus infection..
What virus do you have..?
As long as the recovery partition has not been deleted restart your vaio and when you see the Vaio logo press F10 repeatedly this normally would start the recovery process..
Back-up important data first..
