Делитесь своим опытом!
Has anyone else had problems with Windows 8 on the VAIO Duo 11. I seem to have several and I'm torn between thinking it might be a defective machine, bugs in Windows that might be fixed with a patch or clashes with the antivirus/malware software.
Specification Details:-
Problems (quite a few):-
So all in all a few problems. I'm hoping that a service patch from either Sony or Microsoft might fix these. I remember similar problems with the early days of Windows 2000. I also remember similar problems caused by Norton or McAfee being overzealous in protecting a previous computer that were fixed by tweaking the security centre settings.
I am interested to hear if any other early adopters are experiencing similar problems. If not, then I probably have to conclude it's a problem with the machine rather than buggy software.
Kind regards,
Sean
Hi Sean and welcome.
It sounds like the joys of being an early adopter!
I don't have an answer for you - just a few observations:
1. Did you download the McAfee removal tool to ensure complete removal (if it works on Windows 8)?
2. Many of the problems you list involve Send/Receive operations. I wonder if the Norton firewall is contributing? Is only one firewall active? Windows Firewall Off? What is User Account Control set to?
3. May be worth disabling Norton and relying on Microsoft Security Essentials which is now built into Windows 8 as part of the build just to eliminate Norton as the cause.
Thanks for posting as anything on Windows 8 is of wide interest at the moment. Let us know how you get on. Interested in your experiences.
Thanks Biencogo. I shall try again with Norton disabled. I shall look into the MS innate security software and also check out the McAfee removal. I'm a little time challenged today but shall post the results when I have managed to try the options. I appreciate the fast respons. Have a good day.
Hi seanpepper.
I have asked Sony to look at the Office/Windows 8 problem. If I get a reply, I will post it here.
All sorted by the removal of the Norton software. Mail replication is happening, iTunes downloaded and now happily taking copies of my library onto the local machine from one of the other devices on my network, file sharing across the network is also working. The only thing I did not try yet is the kindle app because the machine's a bit busy at the moment.
Thanks for the advice Biencogo. I shall stick with the MS security software and reinstall the McAfee app that shipped with the laptop. I logged a note at Norton. If there is anything of interest in their response I shall return and post it as an addendum to this thread so others can learn from my couple of days of frustration.
Now it's all up and running I'm able to say that I am impressed with the Duo and its functionality. My major test will come with the use of MS Access. We shall see how it performs with a couple of big databases.
