Hi!
I'm new to vaio world and i bought today the VAIO POCKET vith 40gb HDD. My computer recognises it as a USB MASS STORAGE DEVICE but i can't transfer MUSIC files into it, nor with Vaio Music Transfer nor with Sonic Stage. Vaio Music Transfe doesn't sees the vaio and sonic stage says that the version is not supporting ATRAC3 HDD device. I downloaded the upgrade form vaio website but nothing. Can u help me? Tnx!!! :smileygrin:
Hi Sh1nt4.
Welcome to the forum:smileygrin:
What version of Sonic Stage are you running.
2.3 is out now which may address your problems. Check this thread for more details.
Did you first install the software from the CD provided with the Pocket Vaio before installing any updates from the connect website?
Also, does the device show up as a drive letter on your PC?
If yes, can you see any folders or files on it?
Good Luck
Automan.
I got my vaio yesterday and I got the same problem! i can see the player in my computer, but for some reason music transfer doesn't see it!
I had a similiar issue, there was something in SonicStage like "authenticate" or "initiliase" under control or tools, i clicked on that and I was away, it is no longer there!
you must install the software from the CD and uninstall any version that was there and re-boot before starting with the CD!
i've tried uninstalling everything- the programs, even the usb drivers from device manager, still no response from music transfer... BUT for some strange reason sonicstage started working after the 4th complete uninstall (even tho i didn't do anything different!)... this makes music transfer not working even weirder....
I'm also a new pocket vaio user and i have exactly the same problem! if anyone can help us out please do!!!
