processor boost button
lostmywayagain
Just purchased a Sony vaio fit with a so called booster button that will increase the speed to 2.7 GHz, can anyone tell me what or where this button is, I dont want the hassle of customer sevice the support web site drove me mad.
lostmywayagain
Hi, thanks again for your advice but its gone back to the shop, Ive had other problems wth it, so its back to my 6 yearold Sony laptop, the old one has a far better wifi almost twice the distance and with better reception so Im not really bothered about it.
6 REPLIES 6
rich912
Hi lostmywayagain,
As far as I am aware this model uses Intel turbo boost technology which doesn't require any user input to activate. It automatically cuts in under intense processor activity - hence you can't find a button to press as there isn't one.
http://www.intel.com/content/www/us/en/architecture-and-technology/turbo-boost/turbo-boost-technolog...
Rich
Go n-éirí an bóthar leat
lostmywayagain
Hi, thanks, its just that the advertising blurb says there is a button so I thought I would ask. I think you are right so Thanks again
rich912
Hi lostmywayagain,
Can you please provide a link to the advertising blurb that refers to a boost button?
Rich
lostmywayagain
Hi,go to currys site and look up sony vaio F15A1M2ES check the product details, Im not sure if Ive seen it on the Sony site. Regards.
rich912
Hi lostmywayagain,
Yes I see why the Currys site has caused confusion. If you look at your manual from the Sony support site there is no mention of a Turbo Boost button. Although the specifications do confirm that this model uses "Intel® Turbo Boost Technology".
http://www.sony.co.uk/support/en/product/SVF15A1M2ES
Rich
lostmywayagain
