Question for VAIO EXPERTS: Which keyboard combination inverts the use of the function mode?
tesourodaflora
Hello,
I dont know how it came possible, but at may Vaio 4SM Notebook there are at some keypads little numbers and sines beside them (second level-numbers), which you can use by pressing the "FN" keypad together.
Now this signs are at the top level and appear by pressing them without the "FN"-pad. When I want to write normal Keypads I have to use the "FN" pad.
How can I get it back to the right?
Did You understand my problem right, cause Im not a native inglish speaking person?
Thanx for any help!
4 REPLIES 4
rich912
Hi tesourodaflora,
Try turning off the number lock (press the Num LK key)
Go n-éirí an bóthar leat
tesourodaflora
well done, Thanx for your advise.
I did not thought thats it such easy. I even never recognized, that I have got that "num" keypad.
Thanx
MattWilson
LOL,
Your not the first nor will you be the last.
Everything is always much more simple than you 1st imagine.
rich912
You're welcome tesourodaflora :slight_smile:
