Question
Hailtic
Question
Hi..Im trying to do this update but cant find where the downloaded file is. When I clciked to download it it didnt ask me where to store the file soI assume that it is in the standard Vaio location !!! Can anyone shed some light on this for me please..Thanks in advance :smileygrin:
WinDVD BD Update 10.0.5.164
What is this?
WinDVD BD is Blu-ray and DVD Movie Playback software
Is this relevant for you?
It is recommended to install this update if you use your VAIO for Blu-ray or DVD playback.
What does it fix?
Improved BD-J title compatibility
WinDVD may crash when playing a DVD movie after a BD movie.
How do I perform this update?
1. Exit all running programs.
2. Download this update and save it to your hard drive.
3. When the download is completed, locate the downloaded file in the location you specified.
4. Double-click EP0000215041.exe to run it.
5. Wait while the wizard updates your software.
6. When the installation is complete, restart the VAIO.
5 REPLIES 5
Thalamus.
Champion
Hi Hailtic,
have you checked in C:\updates..?
If it's not there have you tried doing a search for EP0000215041.exe.?
Hailtic
Hi Hailtic,
Yes Ive looked there and also done a search but nothing comes up...Im wondering if its maybe installed the update automatically ? Was going to download it again to see what happens but obviously the link has gone from the Vaio update window.. :smileyblush:
Thalamus.
Champion
Hi Hailtic,
You should be able to check the version number that's currently installed, launch Intervideo WinDVD BD for Vaio, then right click on the WinDVD BD for Vaio application window, from the list select Set-Up.
In the new Set-Up window select the Information Tab..
Hailtic
Cheers Thalamus...Its version 10.0.5.164.94956...So I presume that the update installed itself after download..
Thalamus.
Champion
You're welcome Hailtic.. :slight_smile:
