Quick web access
smarty4040
Quick web access
i am faceing prob to download and install quick web access update version 1.4.5.11.1 on my Vaio vpcca15fg... it stops in tha half way... any 1 have the solution?
That is a Sony Asia-Pacific model.
Are you downloading the update from the Asia-Pacific website here?
http://www.sony-asia.com/support/product/vpcca15fg
Are you following the installation instructions on the download page here?: -
http://www.sony-asia.com/support/download/454991/product/vpcca15fg
It also shows you how to check if the update is already installed - probably worth checking this also.
:thinking:
smarty4040
I have tried all methods but i vein,,, is it the fault of vaio updates or my note book??
If you have tried to download the Update manually from the Asia-Pacific website and also checked to make sure it is not already installed, I think you will have to contact Sony Asia-Pacific Vaio Support by phone or email.
:slight_frown:
