On my Sony VIAO (model: VPCEB3C5E (French version)) with Win 7 Pro, when I click the Advanced button in front of of "Activer la fonction d'entretion de la batterie" (Enable battery care/maintenance function or something like that), nothing happens at all. There is no error message no window showing, nothing.
I do that from an admin account, a checked the windows event viewer, there is no message either there.
What should I do?
Regards
Hi arasse,
Try reinstalling the following utilities in order.
Setting Utility Series.
Sony Shared Library.
Vaio Event Service.
Vaio Control Center.
http://www.sony.co.uk/support/en/product/VPCEB3C5E/updates
Rich
thanks for the answer, but I could not apply it, several of the tools are just not listed at all in the French version
I forced the installation of various Win7 updates and now it works, but I just don't know why
Regards
