RAM Help
rfwebster
RAM Help
Hi all,
I have recently upgraded to vista, on my vaio laptop, and now, ive got a bit more money, i would like to upgrade my RAM. I have oly one problem: I dont know that much about ram, and consequently i have no idea about what type i need.
I have a VGN-FE31H and I currently have 1GB of memory, i would like to upgrade this to 2GB.
Please Help.
rich912
Hi rfwebster,
Yes you can upgrade to 2GB – visit Crucial.com and use their system scanner to determine how many modules are fitted at present. Unless one of the two slots is empty you will need to discard your present memory to fit 2 x 1GB modules.
Go n-éirí an bóthar leat
rfwebster
thank you for your help
