I cant seem to find how to play all my tracks in a truely random order. I am not fully sure how to use the new play orders yet as they are a bit confusing. It maybe there & I may have overlooked it. If not then it is a simple function to program in so I hope they install it into the next update.
Best way I've found to do this is ;
In the main menu of the Vaio Pocket Select - All Songs. Then play any one, during playback turn shuffle on , (press the right menu, left hand column second button down from the top, until you see SHUF on screen).
Hope this helps
