Readyboost TZ21
dameyer11
Readyboost TZ21
I would like to use Readyboost on my TZ21.
I can use it via an Expresscard but is it possible to use an SD card or MemoryStick?
So far exoerience has proved it impossible using fast SD cards. Is it to do with the port rather than the card?
Any help appreciated.
Hi Dan142.
Check for ReadyBoost compatibility here: -
http://www.grantgibson.co.uk/misc/readyboost/?status=all
I think you are limited to 4GB with SD cards and your slot probably does not support SDHC.
I didn't think that anyone used ReadyBoost any more - I think it makes absolutely no difference unless your PC is restricted to a maximum RAM of 512MB and cannot physically take any more. Even then it is almost as quick to page from a modern hard drive when loading large files.
:thinking:
dameyer11
Thanks.
