Recovery disc for VGN-NR11S?
vgangwal
Hi all,
I am new to the community and need ur help. I was creating recovery disc in two sets. My laptop finished with one and asked for second but some how it couldn't finish and I got message to click on finish.
I thought it's done and I tried to format it from the scratch using VAIO center but now it is not completing the recovery process the second disc is not working.
SO NEED TO DOWNLOAD NEW RECOVERY DISC FOR VGN-NR11S. anyone with link
Thanks in advance
Recovery Discs cannot be downloaded - Sony only makes these available to Vaio Owners.
You can recover your Vaio from the Hard Drive without discs. Have a look at your Recovery Guide here: -
ftp://ftp.vaio-link.com/pub/Manuals/RecoTS/2007Q3_RT_EN.pdf
You can try making another set of Recovery Discs using the Recovery Centre - try using DVD+R by Verbatim, Sony or TDK.
If you cannot recover your Vaio or make discs, then you should contact Vaio Support and ask them to send you a set of recovery discs.
:wink:
vgangwal
Thanks Blencogo
But the problems is still there... my laptop doesn't have any operating system so I need to recovery disc...
Thanks for help
Anyone else has better solution?
