recovery discs
-gromit-
recovery discs
hi, i have a vaio svs1511s9es which ive had for a week. is it too late to make recovery discs, if not how many discs do i need aprox. did not make them at start cus i never had any dvd-r discs.
rich912
Hi -gromit-,
It is never too late to create the recovery media as it reads and writes data from the hidden recovery partition. The recovery partition never changes from the time you recieved your computer.
I'm not sure how many disks are required for your model but possibly 4/5.
Rich
Go n-éirí an bóthar leat
rich912
Hi -gromit-,
Rich
-gromit-
hi, rich912 thanks a lot, going to make them asap.
rich912
You're welcome -gromit-:smileyhappy:
