Recovery error 385
thebiscuit
Recovery error 385
Sony VPCEB4E1E reported hard drive error so I've purchased a replacement hard drive. However, when I run the recovery disks the recovery gets to 75% and then fails with error 385. I was about to run a Windows 7 installation disk but found that the recovery partition had been created on the new hard drive so I powered down the laptop and restarted using the 'assist' key but again I got the 385 error. the instruction that came up was to restart and try again but upon restart no operating system was found so I was back to square 1.
Diagnostic tests have not found any errors.
I am guessing that error 385 might indicate a problem with the created recovery disks but so far I have not been able to find out what this error means and cannot fix it. Any advice would be much appreciated.
Many thanks
RickyT
0 REPLIES 0
