Khyrbu
Recovery utility
Hi to everybody,
I missing VRU.exe file, cant start VAIO Recovery utility, where could I download it, or instal from?
5 REPLIES 5
Hi Khyrbu and welcome to Club VAIO.
Did you make a set of Recovery Discs when you first got your VAIO?
You don't say what model you have but you may be able to run a recovery from your hard disc. Try tapping F10 when you see the VAIO screen on startup - this should start the Recovery.
:wink:
rribeiro
I there..
I have the same problem (missing vru.exe)..
I dont have any recovery CD's and F10 does not work..
Can someone help me ??
VAIO VGN-T2XP
Thalamus.
Champion
Hi rribeiro,
Welcome to Club Vaio, :slight_smile:
If F10 does not start the Recovery process then your hidden HDD partition may be deleted or corrupt..:smileysad:
You can purchase a set of Recovery discs via Vaio-Link....
Khyrbu
Hi & Thank to everybody, my recovery partition is OK, has recovered all data manualy, via partition managers, still can't find vru.exe ...
I have drivers & utitlites folders, did install all from there, but there are no recovery utility INSTALL there, the other preinstalled soft is packed in a SONY's own format .... so the problem of finding VRU.exe remein :slight_smile:
... hey ho ... will continue researching
Thalamus.
Champion
Hi Khyrbu,
If you press F10 and recover your C drive to the original factory settings, this will probably install the recovery VRU.exe files...:smileyconfused:
