Regarding screen turning off when the charger is removed.
srinivas019
My VAIO is a brand new one which i bought it 20 days back and the screen is turning off as soon as i remove the charger cable. and i need to connect the charger back and turn on the computer to restart the screen.
adollce
The best solution which i recommend is  :
  1. Disconnect AC
  2. Shutdown
  3. Remove battery
  4. Connect AC
  5. Startup
  6. Under the Batteries category, right-click all of the Microsoft ACPI Compliant Control Method Batterylistings, and select Uninstall (it’s ok if you only have 1).
  7. Either you can go to start - my computer - right lick - manage - a new window is opening called computer management - go on device manager which is located under the Computer Management (local ) on the left panel and on the right panel you see Batteries - u can uninstall Microsoft ACPI and done
  8. Shutdown
  9. Disconnect AC
  10. Insert battery
  11. Connect AC
  12. Startup
Good luck
adollce
  1. Disconnect AC
  2. Shutdown
  3. Remove battery
  4. Connect AC
  5. Startup
  8. Shutdown
  9. Disconnect AC
  10. Insert battery
  11. Connect AC
  12. Startup
Good luck
