Hi
I have just got a VAIO rs404 which came with a remote for use with sonic stage and DVds and stuff which i have found very useful but unfortuantly i need to run winamp instead of sonicstage is it possible to reconfiger the remote software to run that instead of sonic stage
Evan
Evan,
I have a PCV-V1 which also came with a remote control. I've not been able to reconfigure it to work with other apps. In fact I installed Power DVD a while ago and the remote stopped working with InterDVD (or whatever comes as standard), even a de-install/re-install of the apps didn't bring the control back. I had to do a system restore. You should be OK installing other media players though.
If you do find out how to reconfigure it could you post it here, cos I'd quite like mine to work with iTunes instead of Sonicstage.
lots of peeps in the same boat im afraid...
a simple configure program would have been nice but hey, sony wants you to use sony.....
We're having the same issues.
