Remove recovery partition?
petasis
Hi all,
I have just bought a vaio pro (SVP1321M2E), and I have created a "recovery usb", using the tools that were pre-installed.
However, I need to create a second partition D (as my other vaio & desktop pc have). Is there a way to free up some space on the disk, and create a new partition?
From the disk management, I saw that my 128GB SSD has several partitions, and I assume that thee is more than one partitions related to recovery. One before the C: partition which is fairly small, and one after the C: partition, which is arround 19 GB.
Is there any official guide (or tool) to remove the recovery partition (or re-format it into usable space), now that I have created a recovery USB 9and I suppose I can recover from the USB in case something goes wrong)?
0 REPLIES 0
