Request for support: SV-S1511V9EB BIOS
profile.country.de_DE.title
clocksim
Dear Sony Support,
I am satisfied with your SV-S1511V9EB, I like almost anything on/in it, but:
I would like to ask you for the following:
Your latest (and as I know first) BIOS is from 26/06/2012
I need to have a new BIOS containing the following features:
- Latest Microcode update from Intel to i7-3612QM CPU
- SATA port operation mode: AHCI/IDE/RAID
- ENABLE/DISABLE: Programmable TDC/TDP Limits
- CPU/DRAM/PCI/PIC-E tweaking options (bus speed / timing)
- ENABLE/DISABLE: Wireless Adapter / WiFi (WIRELESS green led is always on)
- Change Boot key from F11 to F8, make an option to choos from boot devices
now if I have two USB drives I can choose only the one to boot from
- CPU core enabled (nr.) (here you can disable CPU cores)
- ENABLE/DISABLE: CPU Turbo boos technology / CPU core
- Other new features are welcom...
The three USB port is very close to each other, so I have no chanche to insert
3 USB devices without a trick. In future you can leave more space between USB
ports, or you can put USB port to right and left side too.
Your support is a bit outdated:
- drivers are more than a year ago - I need much time to get new ones
Thank you for your support!
Kind regards!
Bela
0 REPLIES 0
