Restore Click to DVD
PaulMackem
Dear all,
I have mistakenly managed to erase the software "Click to DVD" from my Sony Vaio Laptop. I have just registered on the forum in the hope that someone may be able to guide me through the process of recovering/re-installing the software, if it is at all possible.
Thank you in advance.
LodgeN
Hi paul
I had the same problem and found this!
Right if you go to
Start
All Programs
Vaio Recovery Tool
Then Click Vaio Recovery Utilty.
You should be faced with three options. Recover C Drive ETC.
If you click options, you should be able to find something which says recover pre-installed applications. The Recovery Program will close and the data recovery program will open at which point a list will appear and then you can choose the program. :wink:
You will need the recovery partition to be intact to do this.
Let me know if this works
Dave
