I created two dvd's with the recovery stuff on it with Vaio Recovery Tool. After creating the dvd's I made the parition unallocated (Everything removed) with Norton Partition Magic instead of using Vaio software....now I have a primary partition and I can't move the extra space to my d or c drive.
I want to recover the partition again, and want to know how to do this. I have the FE11S laptop.
thx ahead
Hard question huh lol:smileygrin:
I used partition magic 8 to remove all data on the recovery partition. The partition still exists but because it's a primary disk I don't know how to add this partition to my c or d drive. Right now I have a 7 gb partition that is emty and i can't use. Since I am not allowed to move my C: drive to the left on top of the unallocated space because windows is running on it. Damm this really seems impossible....
Partition Magic will not restore recovery partition ofcourse....
Is the primary drive the one with windows installed or is it the now empty recovery partition
Yeah I know I have that option, but after installing everything already I ofcourse prefer NOT to remove anything. That would cost me a lot of work.
I actually dont want the recovery partition. I just want it so I can remove it again with Sony Recovery Tool. I made the mistake by removing Recovery Partition with Partition Magic. I want to use that space for my c or d drive without removing any data of my harddisk.
About your question wich one is the primary one...well both of the partitions are primary disks, but my c drive where windows media center is installed is active. Sony made the Recovery Partition a primary hidden harddisk. I removied all the data from Recovery Partition with Partition Magic. And now I am stuck with another Primary harddsik because I did not use Sony Recovery Tool to remove that Partition. IF I ONLY COULD TURN BACK TIME LOL :smileygrin:
Who knows a solution.....?
To bad you can't upload pictures here, very annoying....also this postedeting page is bad. When I want to add a Smilies it always puts it at the end of the document. Amateurs.....:smileytongue:
I think you'll need some Linux partition manager which can reenable the partition, but it's dangerous
Beg, borrow or steal a Windows XP installation disk. Boot from it and select the unallocated partition. Format it as NTFS, then remove the disk before it starts to install Windows. As you'll now have a partition with an allocated drive letter, you should be able to merge it to another partition
