Restore to factory settings
JOHNNYBS
Hi there
 i have a sony vaio VGN-NR32L i am trying to restore the laptop back to what it was when i first had ...also if i go the way through the control panel to restart your computer and continue the recovery...i get this message... Windowa cannot restart the computer into the windows recovery enviroment to complete the recovery operation
any ideas please?
5 REPLIES 5
JOHNNYBS
anyone?
Thalamus.
Champion
welcome to the Sony User Community forum..
have you you tried the options from the troubleshooting guide listed below.?
JOHNNYBS
THANKS  fot your reply...
i dont have the discs and the cd player wont even let me burn a disc
and then when i hit return it just takes me to the desktop
JOHNNYBS
anymore suggestions?
Thalamus.
Champion
usaully pressing F10 repeatedly as soon as you see the Vaio should start the recovery process..
There is always the possibility that the recovery partition has become corrupt in which case you would need to contact Sony Vaio support to purchase a set unless you have already burnt a set yourself..
