OK, I've got the RSV-502 and I mainly use it for graphics and video, however I want to add another partition and install XP pro on it...I noticed that (as usual) there is a recover CD but I want to know if there is a hidden partition on the Hard Drive with the recoverable part of XP home because I don't want to overwrite this and mess it all up.
There is indeed a hidden partition. The advice the guys mostly use is: Try PartitionMagic at your own risk. You are much better off just upgrading to Pro from Home to be honest.
Um.....Home to Pro even. Excuse my incoherent babbling.
