Hello!!
Anybody knows if the Vaio VGN-S5 Serie laptops have the same overheating problem than S4??
Thanks so much.
Aqui está o cooler para você usar ao laptop , pois é dificil mante-lo frio ( o laptop). Também tem a propriedade de adaptar ao laptop. Olhe aqui:VantecLaptopCoolers
Hello!!
Thanks so much.
Thanks TonyBeard!!
Thanks Diecer!!
The point is that I have a S4XP and I'm thinking about the possibility to change to a S5XP or S5VP.. but I want to be sure Series 5 do not have the overheating problem.
Cheers.
César
Thanks TonyBeard!!
Thanks Diecer!!
Cheers.
César
Muchas gracias Diecer!!
I see now....
Thanks so much!!
here is my question on e-support and look at the response what a load of <profanity removed by moderator>, sony wont admit nothing, sorry for my language but they **** piss me off
Notes 10-Nov-2005
*** NOTES 10-Nov-2005 Action Type: Info
i have been on loads of websites looking at reports and reviews on the s series, it is known there is alot of heat from the bottom right, i have looked on the usa sites. now something has to be done.
Notes 10-Nov-2005 Stephen
Dear Anthony,
Thank you for contacting us. If the Vaio is overheating it will switch itself off and can only be switched back on when cooled down. I can find no mention of this being a known issue. The only issue that can be the cause is dust on the fan vents, using a compressed air spray on the fan outlet can clear this.
Notes 10-Nov-2005
Dear Anthony,
Amazing!!!!!
No mention of this being a know issue????... you can find hundreds of forum posts describing this problem in S Series... even you can find this info in the Sony official website:
http://esupport.sony.com/perl/news-item.pl?mdl=VGNS560P&news_id=86
Sorry it's in Spanish but describing this problem and saying it is a normal behaviour.
I would you recommend you reply them with this link and wait what no sense answer can give you now.
Cheers.
César
My S5XP gets hot. I have the updated bios. It never shuts down due to heat though. It just gets real hot. It is too hot to keep on your lap for any amount of time. I am kind of shocked at the heat compared to my IBM laptop.
As i said - if you are asking whether it shuts down then the answer is it does not. If you are asking if the computer gets hot to touch - then yes.. it does.
Dub
Dub
