amj.designs
SAFEGUARD PRIVATEDISK
I HAVE TRIED MANY TIMES CONTACTING SONY ABOUT THIS PROGRAM THAT IS IN MY LAPTOP AND I HAVE BEING TRYING TO UNINSTALL,SONY COULD NOT HELP.THEY MAKE SURE THEY PUT THIRD PARTY SOFTWARE & PROGRAM ON YOUR LAPTOP BUT YET THEY DO NOT WANT TO HELP.I HAVE SENT 6 EMAILS TO THE MANUFACTER BUT YET NO REPLY.YOU CANNOT UNINSTALL IN ADD & REMOVE OR DELETE IN PROGRAM FILES EVEN ON THEIR SITE THERE IS NO REMOVAL TOOL AND THIS IS ONLY A TRIAL VERSION.HAS ANYONE GOT AN IDEA HOW TO UNINSTALL IT THANKS
12 REPLIES 12
Thalamus.
Champion
Hmm That's strange I removed SafeGuard PrivateDisk from Add & Remove Programs :thinking:
rich912
Some trial programs need to be activated before they can be removed using Add/Remove programs…..
Go n-éirí an bóthar leat
amj.designs
i'm telling you i could not and it is bugging me,if you ahve can you see in c:\ you will have the folder called UTIMACO it is still there.
tonybeard
GO TO START > RUN> REGEDIT> H KEY CURRENT USER > SOFTWARE > mICROSOFT > WINDOWS > UNINSTALL AND DELETE THE PROGRAM IN THE LIST. jUST DOUBLE CHECK BY MAKING A SYSTEM RESTORE POINT INCASE IT ALL GOES TITS UP.
Thalamus.
Champion
No the folder has gone now.
I agree Rich, but I did not activate the program I just removed it.
Did you actually use the program amj.designs?
amj.designs
no i haven't as it didn't seem that important to me i have tried to use it since i read the replies but i cannot find it in the add & remove also to the reply before this going to run>msconfig>that is one of the longest route to take as i ahve tried it with microsoft it took half hour and still could not tell what program it is.despite the program is not removed in that process you only stopped it.
tonybeard
Regedit not msconfig:smileygrin:
amj.designs
ok sorryn i got something like AB(DEFAULT) TYPE IS REG_SZ,DO I delete
Thalamus.
Champion
There nice airbags Beardo :smileygrin:
