A few days ago, my laptop screen went almost black, with just a faint image of the desktop visible. I rebooted several times and the screen flickers and then goes almost black again. One time the screen came on as normal and then went away again. I don't think it's a driver problem, but could it be? Could it be something loose internally? I haven't dropped the machine or anything, but it is a laptop and mobile by definition and it gets jostled a lot.
It's no longer under warranty and If it's worth taking apart to check something, what should I check?
Thanks for any help.
I would suspect either the cable that goes from the keyboard area to the LCD (connections or damaged cable from opening/closing lid) or the backlight itself behind the LCD.
I had a similar problem on my old HP laptop. The first time it happened the screen backlight had been turned off. I blamed the Gremlins for that one. I didn't touch it and the wife never went beyond the desktop icons so I'm sure it wasn't her.
Over a few years the connections in the hinge must have worn and I found moving the lid back and forth brought it back to life.
I have only had this Vaio for a week so I can't tell you where or even if there is a backlight setting. I know it wasn't in an easy place to find on the HP.
Good luck.
Regards
Dave
Thanks, all, for your replies! That gives me a bit to go on and I'll look a bit harder around the hinges, etc. and other settings.
Larry
