On this picture you can see the problem.
It's a normal for Screen VAIO "FE-11sr" notebook, or I need to send it in the Service for repairing? This PC on Warranty till April 2007.
Thanks for help in advance
Correct me if I'm wrong other FE users but this is due to dual lamp technology?
I would say it's an fault and far away to be normal.
That's what I would say when I'm looking at my PCG-FR315S. (Sreen is like a mirrior but still excellent and without shadows.)
The picture is misleading a bit, as I can see your windows and doors
Is that the reflection of the camera's flash in the centre of the screen...:smileyconfused:
Nah, that's the lamp
No. It's not. I didn't use flash for this picture. Sorry for quality, but you can see the shadow - especially on the left lower side of the screen. I not sure that for new generation of VAIO notebooks this is a normal.
That does not seem very good then....:smileysad:
It's not normal like I said.
A camera flash wouldn't give a result like these. Bad made screen, not more not less.
So your warranty is your friend. Or better your PC dealer.
I'm not too happy with that either, but I hate to say that's not normal for Sony to say "well it is alright?"
