Hej,
I have been using Sony Vaio VGN-FW31J since last year June. This week I noticed that the hard dsik produced weired sounds. First it was as loud as fan sound, then today the clicking sound begin. I am afraid the hard disk is going to die. Then the display backlight blinking and turned off by itself several times today. I closed the lid and logged on and the screen went dark until several times trial, the problem went away. The screen still blinking now and then this evening.
EY
Hi EY,
It sounds like the power board is failing.
I would contact Sony Support as soon as possible to arrange a repair while you are still withiin warranty.
Hej Blencogo,
My Sony run dual systems: Windows Vista (original) and Windows 7 professional (installed 3 months ago). Should I uninstall the Windows 7 prof before the returning?
EY
It is up to you. This cannot be a software problem causing this.
I don't think you must remove Win 7 but Sony Support may reformat or replace the drive so make sure you back up anything important.
Okay. Thanks.
