Hello friends,, someone fixed my laptop but knocked off my scrolling mouse!! someone on here helped me before to download it... can anyone tell me where.. its a Vaio VGN model.. if thats any help..
We will need the exact Vaio model.
Hi Blencogo..
Its a VGN FS515E thanks.
You should find the original Pointing Device Driver on your hard drive in C:\Drivers.
If it is no longer there, try downloading the Original Drivers Package from the Support Page for your model here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-FS515E
Message was edited by: Thalamus.
Hi again... not sure what to download on this page!!!! anymore help please, still not scrolling.. Thanks..
Assuming that you still have the original XP OS then download the original drivers pakage. You will find a folder within that named Pointing. If you have upgraded to Vista then you will find the Alps pointing device driver under the Upgrade tab.
Rich.
Hi Rich912.. I do not have any cds OS.. i am afraid.. also not upgraded to Vista.. running XP service pack 3 as far as I know. I am a beginner!! so any advice should be in plain english please. Thanks.
Hi fiomurph,
have you checked that you do not already have the touchpad drivers.?
Click on Computer
Then C:
Then click on Drivers
Do you see a folder called Pointing.?
Hi thalamus.. showing on screen is under c is Documents and settings, program files, and WInXp.. which one do I check please.
