- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Self Heal Hangs
I've been running Vaio Care, One Click Care. The programme runs for while, then hangs when it gets to Self Heal. No eror messages of any kind. Any ideas? (W7 64 bit OS)
Regards,
Clive.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If its hanging then there is probably a software issue somewhere
I would suggest booting into Safe Mode (hit F10 when booting up) and then uninstalling the Vaio Care programme through Control Panel / Programmes
This should do the trick and you can then reinstall again
If not post here for some more advice
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
OK, Thanks. Where can I reinstall it from?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You can uninstall it from Add/Remove programs.
To install it, you may need to download the installer, if you don't have it in the support site.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If you give your Vaio Model, I'm sure someone will give you a link to the Downloads Page.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Solved! Zone Alarm was blocking the progress of the programme.
Fixed now and everything seems fine.
Thanks for your interest.
Regards,
Clive.
