Should I update my Artheros driver?
gegiegegie
Sony Vaio VPCEC1S1E Artheros AR9285
My Wireless driver is v8.0.0.238 but I see that there are later drivers i.e. v9.2.0.467 so the question is should I update to the newer driver even though the Sony test or Windows Upadte dosnt mention it?
Gee
rich912
Hi Gee,
As Sony do not appear to have released this driver for your model as ‘tested and working’ the old adage of ‘if it isn’t busted then don’t fix it’ would apply. Unless of course you are having problems...
Rich
Go n-éirí an bóthar leat
flogger12345
My own rule of thumb, "Don't fix it if it ain't broken". Anyways, you canalways rollback if you will be getting problems with it. http://imagicon.info/cat/12-13/vbulletin-smile.gif
