Shutdown when I use the DVD drive
pethumph1
I am hoping someone is able to help me. I am having a problem where if I use the DVD drive for longer than an hour or so the system simply switches off, no notice previously goes goes dark. I can switch it back on again and it will work again.
I have no ideas with this and am thinking of formatting and starting again, though I don;t really think this will fix it, just out of ideas.
Does the Vaio get very hot? Try downloading a program that measures CPU temperature.
What model Vaio do you have?
:thinking:
