Slight Problems with my VGN-NR21Zs
Gibbs-
Hey all
Got a couple of gripes with my laptop of 6 months:
- the left mouse button requires quite a heavy push to make it work, not a tap, what could I do to make it function as it once did?
- the following keys: 2,3,4,W,E,R,F2,F3,F4 emit a clicking sound when pressed, it halfway sounds like an old windows error noise, but I know its nothing to do with the computer or any errors, it is just when those keys are depressed. What can I do to stop this as it is driving me up the wall!!!
Thanks in advance
5 REPLIES 5
Ralucutza
i have the same problem as you , Gibbs,with my vaio VGN-NR11S/S .i have to push quite hard the left mouse button to click something. and one more problem , with my Fn+ F4 keys, it doesn`t respond when i want to turn up the volume.
does anybody know why?
i have to mention that i have my vaio for about 1 year .
Gibbs-
Mine also does this every now and then, when I try and up/down the volume/brightness the box doesnt come up on screen. Not too often though.
Thalamus.
Champion
Hi Gibbs,
as your Vaio is only 6 months old I would suggest you open a case with Sony Vaio support, you can do this either by phone or via e-Support, use the following link to find the contact details: Sony Vaio Support
Hi Ralucutza,
welcome to club VAIO.. :slight_smile:
If your Vaio is still within warranty I would suggest that you do the same asap.. :wink:
Gibbs-
Hi I'm taking your advice and contacting e-Support, but where do I find the 'Warranty / Insurance Contract Number' which is only needed for VAIO customers?
Thalamus.
Champion
Hi Gibbs,
if you still within the Sony guarantee period then your Vaio's serial should be all that's required..
