Dear All,
I have a question regarding the Chassis of the Vaio Notebook that I have. I would really really appreciate if someone of you can give me some information on the question that I have. Coz I am really passionate about my Vaio Notebook and this query that I have is like killing me from inside...So all of you please help.
I have attached a file to my question, If you guys can view it just refer to the attachment as my question as it also has a image which I would like to show it to you guys which makes explaining my question simple. Please open the attachment with this post.
Cheers !
Augustya
Hi Augustya and welcome to Club Vaio.
I can honestly say we have not had any reported problems of the black colour coming off the palmrest of the FZ-Series Vaios.
I do not think you need to worry at all about your Vaio.
Anyone else here with a FZ who can help reassure Augustya?
I have a Vaio which is an AR series, the palm rest is also charcoal black by the looks of it. After about 2 months of owning it i noticed the keys on the keyboard started to become very shiny and losing their finish, then i started to notice some shiny areas appearing on my palm rest where that was losing its finish as well, the palm rest on an AR series Vaio is like a charcoal black with a matt looking finish, mine became very shiny, very quickly.
Its as if the finishing laquer they use is very poor.
I can only guess too!
All I can think is that the dye used in the Anodizing process is actually a very dark blue. This gives a black appearance to your Vaio but in very dilute solution it will look blue.
Like all anodized surfaces, the colour will wear off over a long period of time. However, we have had no reports of this happening on your model.
Just to make sure, I would only use a cloth dampened with water to clean your Vaio. Some screen cleaners may contain solvents which are OK on plastics but not so good for metals. Very few computers have metal casings.
Just a damp cloth will be safest!!
No - I think it is all metal.
Magnesium is a strong and very light metal used to make expensive SLR cameras. It is very strong for its weight - it used to be used a lot to make alloy wheels on Formula 1 racing cars until someone found out to their cost that at extremely high temperatures the metal actually burns in air.
http://en.wikipedia.org/wiki/Magnesium
I haven't a clue where the blue tinge has come from. I have discussed the possibilities with you but I can help no further without seeing the Vaio.
If you are worried have a word with the shop where you bought it.
If it is not damaged then I would forget about it and just use a damp cloth in future.
