SonicStage problem
DrPepperMan
SonicStage problem
Hi. I managed to install the software fine but when I go to run sonicstage it comes up with this message: "Updating Sonicstage database. Please restart sonicstage after the updating has been completed." It just stays there and when I click on "OK" a box flashes up saying "Converting Stroage database" and then it dissapears in a split second. And that is it. I can't use sonicstage! I have XP Pro with Service Pack 2, if that is any help. So if anyone knows how to fix my problem please reply! Cheers
6 REPLIES 6
DrPepperMan
Does anyone know what to do? As I have tried everything from searching every page of this site to reinstalling the software. I can't even use the software! Please if anyone knows what to do then please reply.
Automan
Have you tried upgrading to SonicStage 2.2?
http://ciscdb.sel.sony.com/perl/select-walkman.pl for the download link.
Automan.
DrPepperMan
Cheers I will try it.
DrPepperMan
Only one little problem. I'm living at uni behind a firewall so I can't download the update! :cry:
DrPepperMan
I still can't get the installer to download the update! I have no idea of what to do!
DrPepperMan
I still can't get it to work!
