Hi, I bought a Sony Vaio CR21S/W with Windows Vista 32 bit.
Someday ago I receveid as a present a copy of Windows 7 Ultimate 64 bit (I've 3 gb ram) and I tried to install on my notebook. I made the boot from CD-DVD Drive and I've chosen to install Windows 7 in the Windows Vista partition, deleting Windows Vista. Once I finished, Seven started and also some problems started with it.
There are some problem with the extra button of my laptop like Volume + / -, Mute, Capture and AV (the dispaly off button works): they not work.
Also the Fn button does not work (fn+f5, fn+f6 ect they do not work).
And most important the SD Slot reader is not recognized!!!
Also the motion eye webcam and microphone are not recognized.
I tried to download all the originals drivers from http://support.vaio.sony.eu and I installed them, but I can't install all, because many of them are not supported by windows seven (like the sd reader), so many problems still exist (By installing original drivers I've only solved the Volume +/- and Mute button)
Any one can help me? How can I find some windows vista 64 bit drivers compatible with my windows seven ultimate 64 bit? I think it's very strange that I can't find a way to use all the buttons and all the other mentioned features of my pc with a "full compatible OS".
Thanks a lot.
Federico
PS: I read about an "Installation order for the drivers" can it be helpfull?
I read also about Sony DLL, but the are not downloadable frome the vaio support in the page of my vaio laptop model.
Any ideas?
Again thanks...
Hi fedegf and welcome.
Sony will not support 64-bit systems on your model which means you are very unlikely to get everything to work.
Sony have released some drivers (without support and at your own risk) for 64-bit systems - have a look here: -
http://support.vaio.sony.eu/os/vista/64bit/
There are some for the CR-Series which may help.
Thanks a lot for welcoming!
I will try to install that drivers, but I've a problem I can't open the link you quoted to me:
I have just tried it and it is working now.
Sometimes the Vaio servers are a bit slow!!!
moved thread from german to english section of the forum.
(site is working again)
Can fegegf find this thread again if you have moved it?
Not easy for someone from Lombardy writing in english on the german forum!!!!
