Hello All,
Just wondered if anybody can offer me any help or advise????
I have a sony vaio PCG-9P9M (I know its a dinosaur) but still works ok for me...
The problem I have is that I have bought "windows XP Pro" and wanted to install it on a
new 120 gig hard-drive,
Its starts off ok and when it gets to press F8 to except and continue mine does not let me do this no matter what I do nothing happens,although I can when I use anything else.ie spell check???
Is there some protection that sony has put in place to stop you doing this??? ( I can use the recovery cd no problem)
Cheers,
Tam
I hope this is in the right place..........
Hi Tam,
The only possible limitation is the old ATA limit of 137GB so you should not have a problem.
What specification hard disc have you bought? Is it ATA-100?
I think your model is the PCG-K115M (it is always confusing when people quote the chassis number) and I would not expect a problem.
Are you following method 3 in this guide?
http://support.microsoft.com/kb/316941
Is it the F8 after you have seen the license agreement?
Hi Tam,
I have no problem with the Hard-drive only the F8 on the keyboard
