Sony SZ2XP to 2 External Monitors
oceanboy
I would like some help from you guys. I want to connect my Sony SZ2XP to 2 external 17" monitors (in extended desktop mode) so that I got a bigger space to work at when I am home. TI don't need the laptop's screen to be on. Are there any easy and cheap solution to do this?
Thanks a lot, guys.
4 REPLIES 4
Thalamus.
Champion
Hi oceanboy,
Would something like this be what you are looking for... :slight_smile:
oceanboy
HI, Thalamus
Thanks for the prompt reply. But the laptop's graphics card is already capable of running in extended desktop mode, do I really need that Matrox DualHead2Go? Or do I just need a splitter cable? I am a bit confused here.
Thanks for the further help.
Hi oceanboy,
Your SZ can only support two displays - and the laptop display is considered always in use - so it is impossible to support two external displays without the Matrox DualHead2Go hardware (or something similar.
:slight_frown:
oceanboy
Ok, thanks a lot.
