Sony UPnP
Philipljones
Sony UPnP
When I boot up, I get 3 dialogue boxes appear on the screen, (all the same) telling me that Sony UPnP has encountered a problem and needs to close.
What does this mean, it doesn't really have any effect on the performance of the PC
Its a Sony Vaio RS-406.
Any help will be appreciated
kee-lo_
From VAIO-Link
[size=14]Solution A01388Description:When I start my VAIO, I get the following error message: Sony UPnP Framework has encountered a problem and needs to close. We are sorry for the inconvenience.Solution:This error which occur when you have Norton Firewall or Internet Security installed and running. It is due to the fact that Norton mistakenly sees the software as harmful. As a workaround, deactivate the firewall and the issue will be resolved.Important note: Disabling the firewall makes your VAIO vulnerable to attacks and hackers.This issue is due to third party software, please contact Symantec to resolve the issue.
