Having not used my laptop as my main dvd player for a while, I decided to give it a whiz. I loaded up Vaio Zone, put fresh batteries in but I cannot control Vaio Zone using the remote only the keyboard.
Could anyone please help me resolve this problems
Regards
Support Information:
Device Type: Input Devices
Laptop Manufacturer: Sony Vaio FS215Z
Manufacturer: Sony
Model: pcva-ir7u
Interface: USB
Operating System: Windows XP Home
Age of Device: < 1 year old
Hi JLG,
Have you got a directory C:\Program Files\Sony\VAIO Zone Remote Commander ?
If you have try running AvRmtCtr.exe -if you are going to use it a lot, then put this in your startup programs.
If you don't have this directory, you may have to look on your Recovery Media or look in the downloadable Utilities.
