Sony Vaio Duo 11 digitizer pen issues
ioannis1971
Hi, I have a Duo 11 and a) my digitizer pen doesnt register at all any clicks of,the buttons and b) to use it I have to press it hard in order to write down or click something. A week ago it used to be more sensitive. Now I get tired by the pressure I put to write with the pen. I tried to reinstall the drivers through Assist but there are no pen and touch drivers anywhere - including the support site.
Any ideas?
Message was edited by: ioannis1971
stavrosd2006
hi there,
did you put in a new battery? may it was depleted fast if accidentally a button
was kept pressed for a long time.(lets say during storage)
do NOT press hard on screen,you will definetely damge it through time.
Do you have friend, or a Sony Center near you? i would suggest to try stylus
in another vaio to see if it is working on that one,and thus exclude
computer malfunction.
post your results.
Good luck.
stavrosd2006
hi there,
post your results.
Good luck.
ioannis1971
ok I feel like a complete idiot. Changing the battery was something that I didn't think of since I had hardly used the pen and the laptop is 5 months old.
Thanks for the tip! I changed the battery and is working fine now (although in the meantime I have ordered another pen in case the original one was malfunctioning).. Now I have 2!
Thanks Stavros.
John
JayKannan
Have you tried this driver from NTrig? http://www.n-trig.com/files/Win8_Driver_x64_v2.zip
I'm yet to try with photoshop, but it installed okay and doesn't conflict with the existing driver
